Author: Subject: Nosecone??
2ltwin
posted on 3/12/03 at 06:23 PM Reply With Quote
Nosecone??
Hi
Have recently bought a rolling chassis which has been built 6 inches wider than the book, is there a nosecone out there that will fit or will modifications be needed??
Many thanx
dblissett
posted on 3/12/03 at 08:36 PM Reply With Quote
you will need to check the front top section
because standard nose cones are 24" and robin hood do a 26" one
the chasis might be 6" wider but it might have a standard 24" front end
good luck dave blissett
2ltwin
posted on 3/12/03 at 08:55 PM Reply With Quote
Front top section measures 30 1/2 inches accross at the widest point
posted on 3/12/03 at 11:22 PM Reply With Quote
probably stuffed for a prefab one then. It is possible to buy one and cut it in two, and put a section in to widen it. Maybe hard to get smooth though.
Simon
posted on 4/12/03 at 11:50 AM Reply With Quote
2ltwin,
The Viento IIRC is 6" wider than book, so that may be a good starting point!
Simon
James
posted on 4/12/03 at 12:23 PM Reply With Quote
As Simon said, the only pre-made one I'm aware of is for the Luego's Viento.
I've no idea how tall it is though. Contact ChrisW about it as he's the only person I know building a Viento.
HTH,
James
2ltwin
posted on 4/12/03 at 07:32 PM Reply With Quote
Cheers for all the advice, phoned luego but wont sell the nosecone seperate. sha me but Ill probably have to butcher one!
Simon
posted on 5/12/03 at 10:29 AM Reply With Quote
2ltwin
see the nosecone pics in my archive - added 4" to standard nosecone
Simon
posted on 5/12/03 at 01:35 PM Reply With Quote
nice! roughly how wide were your front top and bottom bars? about 28 and 17?
just realised mine may actually be similar to the book anyway. time to measure.
thanks!!
[Edited on 5/12/03 by JoelP]
