Author: Subject: GRP curing in "cold" weather
smart51
posted on 13/6/08 at 04:56 PM Reply With Quote
I'm struggling to get my fibreglass to go off. I've tried upping the catalyst to 3% and 4% but with little joy. I've resorted to the hot air gun to warm it up a bit and help it on its way.
A few days ago when the weather was hot, it was going off really quickly. My garage is unheated but it is a fairly mild day. Cool for June but not cold at all.
What can I do to speed things up a bit?
clairetoo
posted on 13/6/08 at 05:23 PM Reply With Quote
Just warm the garage a bit - not a good idea to heat f/glass to cure it as , when heated gell coat expands , but on cooling it will shrink to slightly smaller than it was before heating .
This can cause all sorts of distortion.......
Its cuz I is blond , innit
Claire xx
Will weld for food......
indykid
posted on 13/6/08 at 05:46 PM Reply With Quote
tent off a section with polythene sheets from b&q or something like that.
it can be a pain to warm a whole garage but to warm a few square metres isn't so much bother.
tom
chrsgrain
posted on 13/6/08 at 05:52 PM Reply With Quote
Use UV activated resin - means you have to work under artificial light to lay up - but doesn't go off at all - then open the doors / take it outside and goes off in a couple of ticks, no matter how cold - its great!!
Chris
turbodisplay
posted on 13/6/08 at 05:57 PM Reply With Quote
could moisture be the problem? I had that when it rained outside working in the garage, water in theair stopped the end closer to the door curing.
Darren
smart51
posted on 13/6/08 at 06:05 PM Reply With Quote
UV resin sounds like fun. Shame I've just bought loads of the normal stuff. I'm not warming it up much, just enough to cure in a couple of hours. I'll give making a tent a go.
twybrow
posted on 13/6/08 at 06:59 PM Reply With Quote
Sounds like the dodgy resin/catalyst then... Hand layup resin should go off with 'summer catalyst' no problem at all @ 2-3% (by volume) in a un heated garage at this time of year.
stevebubs
posted on 13/6/08 at 07:45 PM Reply With Quote
Patience is a virtue...
Where did you get your resin/catalyst from ?
chrsgrain
posted on 13/6/08 at 08:20 PM Reply With Quote
Sorry - badly written post. The UV activating stuff is catalyst to go with normal resin, use it in place of normal catalyst.
May even have a bit lying about somewhere....
Chris
smart51
posted on 13/6/08 at 09:37 PM Reply With Quote
After letting it sit for about 8 hours, I scooped it all off the board I've been using as a "mould" Previous batches could be forced but this wasn't having it.
The resin and catalyst were both from Polyfibre in Birmingham. I've had the same stuff before and had no problem. Probably just a bad lot.
twybrow
posted on 13/6/08 at 09:59 PM Reply With Quote
Was it polyester you bought or epoxy?
smart51
posted on 14/6/08 at 07:14 AM Reply With Quote
Polyester. Low styrene emissions polyester, the same as the last lot I bought.
