Author: Subject: side panles
Stuart_B
posted on 23/6/08 at 07:56 PM Reply With Quote
side panles
hi all, how do you fix the side panle's on?
thanks
stuart
tks
posted on 23/6/08 at 08:16 PM Reply With Quote
well i ppued and popped it on..
PU for vibration.. and pop for strenght..
richard
posted on 23/6/08 at 08:28 PM Reply With Quote
I used a combination of pop rivets on the bottom edge and in engin bay. 5mm screws taped into the chassis under the wheel arch and on inside of top rail in the cockpit area.
ReMan
posted on 23/6/08 at 08:43 PM Reply With Quote
1 pop rivet right at front
5 down wheelarch diagonal
PU adhesive the rest of it
Then half a dozen undrneath to hold unglued return edge with spacers to suit
Then through ally top trim if your using one.
A tip:
Dress the inside of the fibreglass to remove any high spots where it contacts the tubes.
It will stick better and reduce risk of gel coat damage when its fixed down
