Author: Subject: side panel spacers
Stuart_B
posted on 15/7/08 at 04:43 PM Reply With Quote
side panel spacers
hi all, what do you make the spacers out of to go on the un glued edge which you pop rivet on?
thanks
stuart
eznfrank
posted on 15/7/08 at 05:16 PM Reply With Quote
I've not done mine yet but I've heard of people using those cheapo plastic rulers??
indykid
posted on 15/7/08 at 06:49 PM Reply With Quote
which unglued edge?
mine are sika'd all round. on the first one, i filled the bottom edge but on the second i've left it as an airgap.
from memory, it's probably 3mmish though. 3mm acrylic? go see a signmaker's. i'm sure they'll give you plenty of offcuts.
tom
Stuart_B
posted on 15/7/08 at 08:00 PM Reply With Quote
the bottom edge. cheap rule's hmm.
stuart
posted on 15/7/08 at 08:13 PM Reply With Quote
Mine's filled perfectly with air
StevieB
posted on 15/7/08 at 09:18 PM Reply With Quote
I've rivetted the top and will probably just fil the bottom side with sikaflex.
Hindsight says I should have sika'd the whole thing, but never mind.
