jabbahutt
posted on 21/7/08 at 10:54 AM |
getting an accurate profile
Morning all again
Further to my earlier post on my Mac1 sports screen not fitting my Indy scuttle properly.
It appears it's down to the profile of the bottom of the screen not matching the profile of the scuttle.
So I need to reprofile it to match. Anyone got any clever ideas of how to get an accurate profile off the scuttle top so I can tranfer it to the
bottom of the screen?
Any info on techniques greatly appreciated.
Nigel
Mr Whippy
| posted on 21/7/08 at 11:08 AM |
Cardboard, scissors & sticky tape…make a template
Fred W B
| posted on 21/7/08 at 11:10 AM |
This, I know how to do. Get a piece of heavy carboard or thin ply/harboard. Stand it on the scuttle at the angle you want the part to sit. Use some
supports to ensure it can't move. Cut the lower edge approxamilty to match. When it's close, use a block of wood or similar as a spacer,
with a pencil held or attached to the top of it. Slide the spacer across the scuttle with the pencil drawing on the template, so that you get the
exact scuttle shape drawn on the template, but with an offset of the spacer thickness. Cut to this line, and test fit. Repeat with a thinner spacer if
necesary
cheers
fred W B
[Edited on 21/7/08 by Fred W B]
| posted on 21/7/08 at 11:11 AM |
Hi Nigel,
How about making a card template and trimming it till it's right the use that to mark out the sports screen?
Use plenty of masking tape on the screen when you cut it to help prevent cracking/scratching.
Any recent build pics on th go?
Nick
Mr Whippy
| posted on 21/7/08 at 11:14 AM |
ahh no matter how you word it, you were both too slow
smart51
| posted on 21/7/08 at 12:37 PM |
Cut card to basic shape as fred said then run a marker pen along the panel. It will draw a line about a centimetre above where the panels edge.
Or, stick parcel tape to the panel you want to replicate and lay up GRP onto the tape. It won't stick to the tape but will cure to the required
shape.
PAUL FISHER
| posted on 21/7/08 at 12:59 PM |
How about contour gauge.
http://cgi.ebay.co.uk/160mm-PROFESSIONAL-CONTOUR-GAUGE-BRAND-NEW_W0QQitemZ310062074417QQcmdZViewItem?_trksid=p3286.m20.l1116
| posted on 21/7/08 at 04:23 PM |
How about a thick sheet of cardboard, a spirit level and a pen?
Basically then you can "block it out" onto the cardboard.... Just looking for a description of "blocking" on the internet.
It's bloody easy to do, difficult to describe!!
mr henderson
| posted on 21/7/08 at 05:02 PM |
Yeah, but it was Fred who explained how to do it, you simply said what material to use
