| posted on 19/12/03 at 10:27 AM |
Front mudguard clearance
A simple question - how much clearance should I allow between the side of the tyre and the strut of the cycle mudguard support? Of course, I will make
allowance for the flexing of the strut itself - I'm just concerned about the tyre needing 'room to move' or something.
If it makes any difference, it's a 185/70 x 13" tyre on 5.5" wheels.
rgds,
locoboy
| posted on 19/12/03 at 11:09 AM |
Dave,
I have about 3/4 of an inch when static, when i push it toward the tyre it will touch it but it needs quite a bit of force to go that far so during
normal motoring it should be fine.
I can see no evidence of mine having come into contact with the tyre.
Locoboy
GO
| posted on 19/12/03 at 11:28 AM |
main thing to worry about would be tyre flex, so if you've got tall walled tyres or run them on the soft side then you'll have to allow a
little bit more space. Got no measurements for you though, no where near that stage yet...
| posted on 19/12/03 at 12:51 PM |
Col,
Thanks - I was thinking about 3/4"-ish.
GO - tyre flex at the top side walls? How?
GO
| posted on 19/12/03 at 01:01 PM |
Good point, well made!!
Oops, thats what you get for two nights out on the p1ss until 6am and 3am sucessively, and then turning up to work!!
craig1410
| posted on 19/12/03 at 01:02 PM |
Yes I don't see how you would get tyre flex at the top...
However, you will perhaps get deflection of the mudguard due to wind pressure at speed.
Craig.
| posted on 19/12/03 at 01:11 PM |
Put your cycle wing in position and make the brackets to suit it, you don't want it too low to the tyre or it's a pig to get the wheel on
and off. With the guard centred over the wheel you may not need the stay too close to the tyre anyway.
yours, Pete.
| posted on 19/12/03 at 01:20 PM |
It's just that I've made the stays and bolted one to the upright - and it's hard up against the tyre wall!
I did expect this, and I'll be putting a couple of bends in to clear the rubber - I was looking for a few clues as to how much!
Now I have a reasonable idea... (3/4"-ish)
cheers,
