Author: Subject: motorbike fuel cap
tomgregory2000
posted on 2/8/08 at 04:44 PM Reply With Quote
motorbike fuel cap
Ive had a look on the search and cant find any info on the subject,
So has anybody fitted/tried to fit a motorbike filler cap?
They are so cheap but i dont think they have a hose tale on the back.
Tommy
hector
posted on 2/8/08 at 06:05 PM Reply With Quote
your right they dont have tails on back they are part of tank.
The only way you could use one would be to get a damaged tank and cut the filler out and adapt it, but the breakers may not be too helpful in giving you the key as they sometimes sell complete locksets, worth a try thou!
big_wasa
posted on 2/8/08 at 08:00 PM Reply With Quote
You can get a cheap filler cap from a boat.
niceperson709
posted on 2/8/08 at 10:46 PM Reply With Quote
I did it and it worked out fine, as Hector says they don't usually have the tail but that is not hard to sort as for keys that is no biggie as the locks often only have a couple of pins. I bought a smashed up tank with cap and key from ebay and asked the seller to cut out the bit around the filler and send it to me (to save postage) check my blog to see how it turned out.
If a breaker does not want to sell you the key ask to borrow it and have a copy made ...
Best wishes IAIN
life is not the rehearsal , it's the show so don't sit there thinking about it DO IT NOW
http://iainseven.wordpress.com/
