Dave Bailey
| posted on 3/8/08 at 06:53 PM |
Panel adhesive for sealing the Windcsreen frame to scuttle
Which Black PU adhesive is the best?
Wurth or Tiger? (in black)
Can it be removed for replacing a screen etc or is it permanent!
Dave B
[Edited on 3/8/08 by Dave Bailey]
jacko
| posted on 3/8/08 at 07:36 PM |
I don't know about Wurth sealer but we use Tiger sealer at work and it bloody good don't get it on your hands
Dave Bailey
| posted on 3/8/08 at 07:50 PM |
Can you get the joint apart if you need to?
smart51
| posted on 3/8/08 at 08:15 PM |
You can cut along a seam of PU with a [very] strong knife. I wouldn't use one with a thin blade because of the risk of it snapping but a sturdy
knife would do it. PU is like a hard rubber when set.
| posted on 3/8/08 at 09:09 PM |
Unless you are going to fit a hood I wouldn't bother,the rubber sealing strip would be OK. The first time you get caught in the rain you will
see why.
Dave Bailey
| posted on 3/8/08 at 09:23 PM |
I do not have the rubber seal so was planning to seal with the PU because the profile of the bottom of the screen does not match exactly the scuttle.
I take it that with no roof you mean you will get wet so a leaking screen is not important!
Dave B
contaminated
| posted on 3/8/08 at 10:45 PM |
Used black silicon from Wickes on my aero screen!
