<<  1    2  >>
Author: Subject: steel panels
posted on 13/1/04 at 06:50 PM Reply With Quote
steel panels
anyone want to discuss the pros and cons of using thin guage steel for panels instead of aluminium?
for my contribution, its a shitload cheaper, not scandilously more heavy (any figures anyone?) and similar in how it wuold be fitted.
plus it can be tacked/welded in.
i ended up with 22g sheets, tacked round, then hopefully made airtight with some strong tape inside.
ugly i know, will probably rivet the side panels.
any thoughts anyone?
stephen_gusterson
posted on 13/1/04 at 07:15 PM Reply With Quote
I think on a std locost, people struggle with the rear boot panel - ie getting the curve and the edges......steel would make this harder.
a refreshing change from people trying to make things lighter
beware that steel is approx 3x the weight of alu
atb
steve
PaulBuz
posted on 13/1/04 at 07:35 PM Reply With Quote
steel is what i used joel.
Not out of a cost issue but for the long lasting good look of the panels.
there's nothing worse than an ally panel with dings &dents in it when it catches the light.
Pics in archive.
ATB Paul
chrisg
posted on 13/1/04 at 07:50 PM Reply With Quote
Yep, my sides and rear panel are steel. I knew it was something I could work with.
'Course then I spent six months making an ali nosecone!
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
jacko
posted on 13/1/04 at 08:09 PM Reply With Quote
hi all
i used plastic coated steel panel for
inner panels like they use on outside
of buildings about 22g one 10 x 4
sheet does all looks good too
jacko
paulbeyer
posted on 13/1/04 at 10:53 PM Reply With Quote
Chris,
You got any pictures of your car? I've seen you plenty of times but your web site only shows an upside down chassis.
7 out of 10 people suffer with hemorrhoids. Does that mean the other 3 enjoy them?
Simon
posted on 13/1/04 at 10:54 PM Reply With Quote
The only downside is rust, but it'll be no worse than the rest of the chassis, just ensure it's painted and rustproofed properly.
Simon
chrisg
posted on 13/1/04 at 11:17 PM Reply With Quote
Originally posted by paulbeyer
Chris,
No I am an international man of mystery.
Theres a couple on my photo archive, but the website's due for a complete overall, with some better piccys.
Chris
mangogrooveworkshop
posted on 13/1/04 at 11:51 PM Reply With Quote
My ten pence worth is not to use ordinary steel plate but to use a product called ZINTEC.its used in the bus body building industry for cladding the busses. It is treated to resist the rust. An old friend Henry Koekemoer used it for his 1800 toyota powered seven replica in Durban (High humidity and Salty air) with no problems. Slight weight penalty but good price advantage. Easy to work and cuts great with a nibbler.Fixed with the traditional rivets easy to replace if you ding it. Spray painted you would have an excellant finnish.
Another advantage is that it does not dent like soft ali. Advantage 3 No reaction between the chassis steel and ali.
stephen_gusterson
posted on 14/1/04 at 12:21 AM Reply With Quote
think my dad used to use that at the place he works. used to make me project boxes from it when i was n electronics hobbyist as a kid.
i think its zinc plated steel......
atb
steve
posted on 14/1/04 at 09:22 AM Reply With Quote
time to get a rivet gun now... i hate spending money!
thanks for the opinions guys.
posted on 14/1/04 at 12:51 PM Reply With Quote
I used a sheet of zintec for the panel behind the seats. I found a load of it at the scrapyard left over from the local boiler factory panel shop. It has a galvanised finish one side and the other side is like a primer.
yours, Pete.
Mix
posted on 14/1/04 at 01:27 PM Reply With Quote
Weight of sheet metal
Here are examples of the weight, (in pounds per square foot) of sheet metals:
22swg (0.7mm)
Aluminium 0.371
Mild steel 1.142
14 swg (2.0mm)
Aluminium 1.06
Mild steel 3.26
Mick
posted on 14/1/04 at 01:31 PM Reply With Quote
...but remember that you don't need use the same thickness to achieve the same rigidity and strength.
I used 16swg (1.6mm) ali for most of my panelling. I'm sure that 22swg steel, or perhaps even thinner, would be as good with very little weight gain.
cheers,
Mix
posted on 14/1/04 at 01:39 PM Reply With Quote
16swg (1.6mm) Aluminium sheet weighs 0.848 pounds per sq foot.
Mick
MikeR
posted on 14/1/04 at 02:28 PM Reply With Quote
i had this debate with myself over the floor. In the end i plumped for a steel floor as it was cheeper and easier to fit.
Its not just a case of weight over strength, the matterials have different properties.
posted on 14/1/04 at 07:22 PM Reply With Quote
so essentially 22g steel is similar in weight to 14g ally. i know the steel is very easy to bend, how easy is it to form the aluminium into curves etc?
ps i made a very loud shimmy board like rolf harris played, about 2ft by 1 ft. Could hear it echoing off neighbours houses, which was fun.
posted on 14/1/04 at 08:14 PM Reply With Quote
Nearly all the curves in the Locost's bodywork are in one plane, i.e. a straight bend, or a gentle curve, in one direction only - easy, no matter what material you use.
The only place where you'd have to get creative is at the top of the rear panel, particularly at the curved corners. You have to bend the sheet round the curve, which is easy, then beat the metal over the round tube, which is 'interesting'. When you get the technique right (in my case, after an initial failed attempt) it isn't too hard in ali. It would be near-enough impossible in steel, unless you're a master panelbeater!
cheers,
pbura
posted on 14/1/04 at 08:37 PM Reply With Quote
A good technique for the corners is to cut away a semi-circle so that the metal covers about a third of the inside of the tube and not bother with rivets on maybe 60 degrees of the curves. That way the steel won't want to bunch up.
Seen this done once or twice, but can't remember where. Maybe someone can kindly post a pic.
Pete
Pete
stephen_gusterson
posted on 14/1/04 at 10:18 PM Reply With Quote
mix's figures show what I said
alu has a density (weight) approx 1/3 that of steel.
I know this cos I design x-ray machines for a living that find metal contamination in food. Xrays work on density, and I can vouch as a fact alu has a specific gravity of approx 3 whilst steel, iron, copper, etc are all around 7.5 - 8.0
dont bother using gold pannelling - its got a density of approx 22.
atb
steve
flyingkiwi
posted on 15/1/04 at 09:19 AM Reply With Quote
oh crap, so I'm going to have to chuck away all that gold then
It Runs!!!!! Bring on the SVA!
posted on 15/1/04 at 09:30 AM Reply With Quote
A bit OT, but what the hell...
If anyone's in the City of London, have a look in the Bank of England's museum - they have a genuine bar of gold that you can touch (it's in a heavy plastic box, and a security man sits nearby...). Last time I was in there, it was worth about £85,000.
Anyway, you can reach in the box and try to lift it - your arm is fairly straight, and few people can lift it off its cradle.
Makes a joke of all those war films where you see large boxes of ingots being lifted by one man, and hurled into the back of a lorry!
cheers,
stephen_gusterson
posted on 15/1/04 at 09:49 AM Reply With Quote
about 1980, when I worked in CCTV we put a system into a bonded silver warehouse on the thames, next to hms belfast.
There was loads of the stuff. I tried to pick one up, and it wasnt that easy!
In the recent 'italian job' movie, they used 3 minis - supposedly modified - to transport a truck of gold. Didnt seem to affect the 0-60 times too much.
pretty crap movie actually
but no where near as bd as 'league of extrodinary gentlemen'.
atb
steve
posted on 15/1/04 at 04:12 PM Reply With Quote
I looked up the weight of that BoE gold ingot - 400 oz, or 25lb!
DJ
locoboy
posted on 15/1/04 at 04:16 PM Reply With Quote
Too much time on your hands DJ
Locoboy
<<  1    2  >>
