trailered my car to jdm dyno this afternoon for ecu to be fitted and wired in so will have it running for the weekend! rear exit exhaust now complete,
oil lines re done with braided hose and adonised fittings,clutch cabele done so blog update this weekend.
i want to upload a video of startup this weekend but only have an i phone original. can i upload from i phone to laptop?
I look forward to hearing it!
I've decided to go for omex for my management. I found out you can convert it to using a single coil pack and put a crank position sensor with a
trigger wheel on to be able to use the cheaper 600 ecu.
Not long till uni is done and I can get to starting mine!
how does your coolant temp guage work? or are you running a seperate temp guage?
Do you mean with the standard dash? I am not at that stage, but if it doesn't work with the standard dash then I'll get a separate gauge
yeah with standard dash. ecu controls coolant temp guage and many more. it may well be financially better to get seperate clocks to run with your ecu than buying a load of seperate guages as well as the honda clocks! just a thought
