Hi all.
I'm looking into the MNR for my next project and just putting a couple of cost plans together. I fancy trying out the hayabusa route as been
down the r1 route in the past with a mkindy. My question is do I need to dry sump the engine as this adds quite a lot to the figures. Guess I'd
be looking at an additional 1200 quid.
Any advice or info would be appreciated.
Adam
in a word,if pushing hard on track,yes! some may say otherwise and many have run them without issue but id run the sbd d/s system and sit the engine down as low as possible in the chassis.
Thanks for the reply
. I won't be on the track if I'm honest so mainly road use.
Adam
There expensive engines to replace and my opinion when I built mine was that it's better safe than sorry £1200 well spent !
Spend your money where it is needed, dry sumping is the way forwards on a busa if you want to go on track.
You may get away with a swinging pickup for just road use, but you will risk starving the engine of oil on track. Yellowcab's thread shows you
what happens when you don't dry sump.
I see a lot of builds where people don't spend the money where its needed, i know its meant to be low-cost... but it will catch you up in the
end!
[Edited on 12/5/14 by jwhatley]
Likewise, given the price of Busa engines it is worth protecting your investment. I dry-sumped mine but some fit an accusump for added protection if they go down the baffled sump route. Swing pickups are excellent but there is a small risk they will jam and in that situation an extra burst of oil from an accusump may get you 'round the corner without oil starvation.
