Hi all.
I've just received the calipers sliders, but I have a 6mm gap from the slider to the adaptor plate.
What should I do? What am I doing wrong?
Rears before disc / adapter plate
You can see the gap between the slider and the adaptor plate
Joao
Is the disc located properly?
I haven't done one of these, but I suggest making another spacer plate for the two lugs. You could use bushes, but make sure they are thick
enough to stop any flex in the bolts.
Another option is to make a spacer to go behind the adapter plate or make a thicker adapter plate. This would be the best and strongest option.
[Edited on 30/5/2006 by nitram38]
Originally posted by chris mason
you need to push the hub all the way on to the shaft, there's a gap and thats where your problem lies
Chris
Thanks a lot.
Indeed it was not fully pushed. I bit of... forced pesuation was needed, but it is all right now.
Thanks again.
Joao
dont forget to torque the nuts to the correct setting and keep checking them for the first 200 miles as with new bearins etc they can come loose
