bassett
| posted on 25/1/09 at 11:28 AM |
Safety Washers - Which Order
Hi, I cant get on to the manual on my computer so can anyone tell me in which order the safety washers go on. I also have the 2 rod end spacers.
Adam
stevec
| posted on 25/1/09 at 11:33 AM |
If you mean flat washers and split washers, the split washer goes against the nut.
Steve.
prawnabie
| posted on 25/1/09 at 12:04 PM |
The smaller end of the washer goes nearest the rod end, followed by the spacer.
HTH
Shaun
bassett
Hi, I have the MNR cortina style uprights with rod ends on both upper and lower wishbones. The two spacers go either side of the rod end and i assume
the safety washers go last before the nyloc nut but need confirmation on that really.
Adam
gr8ging
| posted on 25/1/09 at 12:34 PM |
I fitted mine without the spacer (top wb), and there is not enough thread to fit a safety washer to the bottom wb (outboard) I'm going to try
and find a thinner nut so I can fit the safety washer as it scares me to leave it off. My car is not on it's wheels though, so I will have to
see if this gives me enough travel without the safety washer touching the rose joints once on the ground. Travel seems limited at the mo and
I've tried with and with out the spacers.
that doesn't really answer your question does it!
Hopefully Marc will be along to clear it up.
Weaseling out of things is what separates us from the animals.... except the weasel.
You couldn't fool your own mother on the foolingest day of your life with an electrified fooling machine!
bassett
| posted on 25/1/09 at 01:09 PM |
Is the safety washer on the nut side of the rod end or other side closer to the centre of the upright?
gr8ging
| posted on 25/1/09 at 03:02 PM |
Nut side. If it was to 'let go' the WB can not go any where because of the upright, so the washer goes on the nut side to prevent the WB
passing the nut and becoming completely free from the upright.
I copied the pic in this thread http://www.locostbuilders.co.uk/viewthread.php?tid=102471
(page 4 of MNR forum)
Not sure what joint is used on the Inboard, but my lower joint is much thicker and does not leave enough tread to get the safety washer and lock nut
on
bassett
| posted on 25/1/09 at 05:40 PM |
Cheers gr8ging i know it sounds stupid but i like making sure on these safety things especially as i know ive put it together
Adam
