Triggerhappy
| posted on 1/6/09 at 11:33 AM |
VortX super front end.
I have trouble in getting front camber correct.
The upper a-arm is fully "threded" in.
And lover a-arm´s inner rosejoints have aprox 20mm visible thread....how much thread can i safley wind out?
Obviously i have positive camber right now...it seams to me that lower A-Arms are simply to "short"....???
What goes?
[Edited on 1/6/09 by Triggerhappy]
Im from Sweden, so im escused...The Muppet drummer for president!!
blakep82
| posted on 1/6/09 at 12:06 PM |
i think for things that get screwed in (rose joints, top ball joints etc) i think they should should have 1.5x of the diameter of the thread screwed
in, if that makes sense
________________________
pwl
| posted on 1/6/09 at 09:20 PM |
I had the same problem, just the other way around, it was the top one that was to short.
I have the rose joint so long out, that there is only about 1 cm of thread in the wishbone, I was a bit nervous about it, but it has bin holding up to
some hard track use.
I suspect that there is a narrow and wide track version, and that they sometime bye mistake mix the wishbones.
PWL
Triggerhappy
| posted on 16/6/09 at 12:58 PM |
Yes it seams i got wide track upper and got the narrower lower´s....new lower´s is on it´s way.
