Author: Subject: light at front end
brians25
posted on 26/6/09 at 07:02 PM Reply With Quote
light at front end
high guys, i have just recently purchased a mnr vortx firebalde, it seems to be very ligh and vague with the steering at around 80mph plus, is this common or is it needing a good geo setup
Howlor
posted on 26/6/09 at 07:09 PM Reply With Quote
Hi and welcome,
Is it the inboard version?
pewe
posted on 26/6/09 at 07:15 PM Reply With Quote
Probably down to needing a good set-up re castor, camber and toe-in.
Well worth the money to have it done professionally by someone who knows what they are doing.
Mine felt as if it was going into a tank-slapper until the local race shop set it up properly.
Enjoy.
Cheers, Pewe
brians25
posted on 26/6/09 at 07:20 PM Reply With Quote
it's an outboard model, would just a geo setup do or would it require a full corner weighting as i am in west lothian scotland an not many places about that can corner weight, geo setup is no prob though
Steve Hignett
posted on 26/6/09 at 07:35 PM Reply With Quote
Put your location in your profile, and you may have someone nearby that could help!
posted on 26/6/09 at 07:58 PM Reply With Quote
What you describe is exactly the handling you would expect if the suspension is toeing out on the front.
However check the tyre pressures before doing anything -- try 14 psi fron 16 psi rear.
If that dosen't give an improvement the course of action is
(1) Check/set ride heights as the car normally loaded (ie with driver + fuel )
(2) Set corner weights -- (again as normally loaded)
(3) Check front toe in (again as normally loaded)
(4) Check rear toe-in (again as normally loaded)
nitram38
posted on 26/6/09 at 08:06 PM Reply With Quote
You haven't included
CHECK THE CASTOR !
Probably not enough............
posted on 26/6/09 at 08:30 PM Reply With Quote
One cause of vague steering at speed is incorrect ride height - personal experience is that the car should ride a bit higher at the back. This is also Westfield's recommendation.
If it's a bit higher at the front the the wind gets under the nose and takes some of the weight of the front tyres.
stuart_g
posted on 26/6/09 at 08:39 PM Reply With Quote
Set the front lower wishbones parrallel to the floor, this will give you approx 100mm ride height at the front. Then set the rear ride height measured just in front of the rear wheel arch to 125mm. Castor will be built in already on your wishbones so no need to check but if it is still not right after setting the ride height then a good geometry and corner weight setup will be money well spent.
[Edited on 26/6/09 by stuart_g]
brians25
posted on 27/6/09 at 11:51 AM Reply With Quote
thanks for all your help guys. i'll do the pressures an ride height an see how it feels, wouldn't be surprised if it was wrong as the previous owner was a bit crap at doing stuff, i am going over the car fixing all his poor work,
jambo
posted on 28/6/09 at 06:08 PM Reply With Quote
IS that the black fireblade from p. heads
brians25
posted on 29/6/09 at 06:45 PM Reply With Quote
yep it certainly is, previous owner wasn't a engineering sort by the looks of things, so just tidying bits up a bit, it's pretty quick but my toyota supra would still kick its ass all the way to a 100 and then well beyond
not sure how quick these carbed blade car s are supposed to be?
[Edited on 29/6/09 by brians25]
