daniel mason
| posted on 14/4/10 at 07:08 PM |
wishbone advice please
when looking through the mnr archives i noticed that the front upper wishbone has one bar that is connected very close to back of camber adjuster and
one which is slightly more outboard where it connects to camber adjuster bar!
every mnr in the archive has the bar closest to camber adjuster towards the rear of the car but it does not look correct on mine. any help is welcome
and will post pics to show;
pic 1 is the way that looks correct to me but not how others are
daniel mason
pic 2 is how others are but looks off to me
| posted on 14/4/10 at 07:19 PM |
For positive caster (to give self centering ) the top ball joint centre should be rewards of the lower ball joint centre
http://en.wikipedia.org/wiki/Caster_angle.
| posted on 14/4/10 at 07:23 PM |
Picture No 1 would give very little (if any) setback and therefore little/no self-centreing. No 2 gives the required setback and will self-centre
better.
Phil
RichardK
| posted on 14/4/10 at 07:28 PM |
Number 2 looks better to me
Rich
Gallery updated 11/01/2011
marc n
| posted on 14/4/10 at 11:36 PM |
hi daniel
please email us for the latest build manual, it will make life a lot easier for you, it will take you through to rolling bodied chassis stage with
ease. the bracket positions / wishbone design has has changed since the old car you had hence wishbones etc look different if you monut the wishbones
as per pic 1 bad times, please please ask us if your not sure, thats why we have a help line via email its no trouble at all we want you to have all
the help you need to build as good a car as possible
best regards
marc
please email rather than u2u
chrismnrltd@btinternet.com
marc n
| posted on 14/4/10 at 11:39 PM |
p.s
the ammount of cars we see who have done build blogs of how they where screwed together !! if i had a pound !!!
if in doubt please ask
