Winston Todge
| posted on 4/4/07 at 05:18 PM |
Tracking ideas!?
Right I'm coming to the point of getting the car on the track before SVA prep, to bed it all in. I haven'e given the tracking any thought
yet and am in a fairly confined space in the garage...
How have people set up their VortX RTs? What's a good base setting for some self centering and good handling?
Any ideas are much welcomed!
Non MNR specific advice is also welcomed!
Thanks for any pointers...
Chris.
chockymonster
| posted on 4/4/07 at 05:48 PM |
I set mine up using dunlop tracking gauges and a camber gauge.
From the note on the garage wall:
Front
1.2 deg -ve camber,
1mm toe in per side
front bone parallel
Rear
1.5 deg -ve camber
1mm toe out each side
ride height 35mm higher at the rear
marc n
| posted on 4/4/07 at 06:15 PM |
for the tracking part
best bet is two poles wood, steel whatever, grooves in each end of poles, fishing line and some lead fishing weights, and four axle stands, one pole
at front of car one at rear, string line inbetween them in the grooves of your poles ( fishing weights are for each end to give the fishing line some
tension and make sure its taught ) measure distance from hub centre on rear set so strings give equal values each side set front end same, measure
wheel rim front and back and hey presto you have your own tracking gauges
camber is a tricky one if your garage floor isnt too level, but if you send me an email in the morning i can measure the length of my top arm and that
will give you a near enough guide
cheers
marc
please email rather than u2u
chrismnrltd@btinternet.com
bitsilly
| posted on 6/4/07 at 04:10 PM |
Any chance of you publishing some recommended settings as a starting point?
G.Man
| posted on 6/4/07 at 10:38 PM |
marc
have emailed you for front geometry settings, castor, camber toe etc..
no reply as yet
Opinions are like backsides..
marc n
| posted on 6/4/07 at 11:34 PM |
sorry all been away from work due to family commitments will try and get in tomorrow or monday if i can its a bit difficult at the moment as we are
trying to sort out the final wedding arrangements as its coming up very soon, and i havent even seen where it is yet
i will try my best if not it will be tuesday before i can get to my work computer
cheers
marc
marc n
| posted on 6/4/07 at 11:36 PM |
forgot to add please dont ask for info on here as i quite often forget, it is always better to email or phone rather than u2u
cheers
marc
