Author: Subject: My finished dash
stuart_g
posted on 11/5/08 at 04:46 PM Reply With Quote
My finished dash
Just thought I'd post a few pic's of my completed dash.
[Edited on 11/5/08 by stuart_g] Rescued attachment P1010004.JPG
stuart_g
posted on 11/5/08 at 04:47 PM Reply With Quote
speedyxjs
posted on 11/5/08 at 06:16 PM Reply With Quote
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 11/5/08 at 06:36 PM Reply With Quote
hang on, is your car red or orange..
Funny what light and cameras can do.
Dash looks great btw!! Good work
Johneturbo
posted on 11/5/08 at 07:26 PM Reply With Quote
That looks spot on stu, great idea with sinking the clocks into the dash
Davey D
posted on 12/5/08 at 03:29 PM Reply With Quote
Have you sunk them in so that you wont get any issues with SVA?
i have mounted my 5VY clocks onto the dash in the centre where yours are, but im a little concerned that Mr SVA wont like it as they stick out, and are in an area that will get tested for radius edges
[Edited on 12/5/08 by Davey D]
Johneturbo
posted on 12/5/08 at 06:18 PM Reply With Quote
Mines the same Davey, half are in the exempt zone, the side with the buttons won't pass radius, i dont think, so might cover with foam or make a plastic dome, or just hope they don't check!
stuart_g
posted on 12/5/08 at 09:01 PM Reply With Quote
I really wanted the clocks to be above the steering column but there was not enough space and the steering wheel would have covered most of them. With them in the centre of the dash the speed is hard to see on the far left of the clocks so I decided to make a recess out of fiberglass to tilt them towards the driver and also to get over the SVA problem as they did not fit within the 127mm radius of the steering wheel.
