Quick question for the collective wisdom...
My manufacturer supplied brake lines are incorrect lengths (or my routing is wrong!)..
I therefore decided to make my own, and purchased a roll of kunifer off fleabay - however my copper lines are BS marked, while the kunifer pipe isnt..
Is this going to be an issue for mr IVA? Should i just use the Kunifer to practice my flaring or is it good to go on the car?
Advice appreciated.
Cheers folks
Issue...No
Use on the car....yes
[Edited on 14/9/12 by snapper]
The BS number is just a standard for industral/general use.
I would take the easy route and make the longer lengths of pipe run in two sections with a joiner. Use a proper joiner fitting which can
be found in either a female joiner for male to male or a male joiner for female to female joints.
If you make the long pipe in two sections it makes fitting and maintenance easier and you can shorten and re-use the pre-made pipe you were
sold.
[Edited on 14/9/12 by britishtrident]
Cheers fellas - that's my weekend sorted
