Hi Guys,
wondering if anyone could shed any light on my carb problem..
I have just built up my engine from a quick strip down and check over a few weeks ago..
I have just remounted my carbs and when the engine is running, i can see down one of the trumpets that it is totally flooding the 4th cylinder with
fuel.. (i can see a steady flow of fuel filling up the trumpet in below the slide.)
What would cause this?
Im not too experienced with carbs, but my 1st impression was a sticking float?/float problem?
I didnt want to start and dismantle the carbs because i know they are quite finely tuned piece of kit and i am more of a lump hammer and sledge kind
of guy!!
Any help appriciated.
Iain
[Edited on 22/8/11 by Benzo]
You are right, it is likely to be a sticking float valve. They are easy enough to remove and clean out.
Stu
Stu
If you've flooded the cylinder make sure you change the oil, could well be contaminated with petrol
Thanks guys, up and running again now
Out for a rip last night, all appears fine.. Forgot how much fun it was! Can't wait to get an '08 CBR1000RR engine in!
ha.. have had many frustrating evenings playing with those airboxes
seem to work well when on though
