Hi all,
With my DD2 came an Oil Pressure Regulator/Sensor.
After some Google searching im a bit confused
Where do I fit it?
Is it a case of just removing the Oil Sensor on the block or is it something to do with the Oil Pump ?
Yep that's it, remove the oe sensor and fit the etb one in its place. Providing the threads are the same that is.
Thx Adam, that's the one just above the sump, toward the front requiring a bullet push on connector right?
So that makes sense but where do I then fit the Oil Temperature Sensor then!
I fitted oil temp sensor on my other tiger zetec in the sump plug. Just bought an adapt or. Not necessary really as long as you can see your oil pressure. I have not fitted this to my tiger
