jimmyjonga
| posted on 28/6/05 at 11:27 AM |
join in brake pipe - fail point
through one thing and another my rear brake pipe has has join in it - will this be fail point when it comes to sva??
mookaloid
| posted on 28/6/05 at 11:29 AM |
Don't see why it would fail - as long as it has been done properly and doesn't leak!
| posted on 28/6/05 at 11:52 AM |
I put a join in mine, using a proper coupling, so that I could insert a brake balancer if I needed one (I didn't). The tester in Chelmsford had
a really good look at the brake pipework and didn't say a word (it's very obvious).
Basically, do a proper job using the right bits, and ensure that it's well supported.
rgds,
DEAN C.
| posted on 28/6/05 at 05:43 PM |
Its standard on most new cars and definately accepted practice for MOT etc.
Once I've finished a project why do I start another?
indykid
| posted on 28/6/05 at 05:53 PM |
mine has an obvious one just in front of the drivers footwell, (the only way the mk pipework would fit) and it wasn't commented on at sva.
it was one of the hardest to stop leaking, but no quibble
tom
Danozeman
| posted on 28/6/05 at 06:05 PM |
Joins are perfectly aloud on cars. Hgv's are a different matter.
Dan
DEAN C.
| posted on 28/6/05 at 11:18 PM |
Dont know if that counts,as nearly all Hgv's are air brakes and I've fitted plenty of joints in air lines.
Of course the prospects of failing HGV tests are a litttle more severe,I know from bitter experiance as I am responsible for a large fleet of vehicles
more than half are HGV's.
Of course its better not to have joins if possible but if done properly it should not pose any problems :
| posted on 29/6/05 at 06:38 AM |
As long as a connector designed for the job was used it is fine.
BUT you can't just use a male tube nut screwed straight into a female. Couplings to join brake pipes can be bought as male to male or female
to female.
http://www.vehicle-wiring-products.co.uk/VWPweb2000/brakes/brakes.html
jimmyjonga
| posted on 29/6/05 at 01:13 PM |
glad to hear the last point - currently i have just put a female straight into a male - will change.
thanks james
indykid
| posted on 29/6/05 at 01:20 PM |
to female.
could be why mine wouldn't seal!
it passed sva like that though
now that it's sealed, what are the implications of leaving it like this?
it's pure copper lines btw
tom
