Author: Subject: Light Front End / Steering
Flamez
posted on 25/9/09 at 12:55 PM Reply With Quote
The car is running sweet now I finally have a decent airbox and I've reset the Power Commander to "akroprovic" [it seems to work well with the exhaust and cat].
However when accelerating hard and fast the front end seems so light. The geometry seems to be ok and is set up as the factory suggest. tyres are set at 20psi. the car turns in well and self centres too. But I find the lightness a little disconcerting.
Is it me are all 7's light at the front when pressed on? I guess I have been spoilt by previous high range cars that stiffen the steering up with speed and I just need to get more miles in and build the confidence up.
Would raising the rear end suspension help by putting a little more weight on the front?
How do other mac drivers find their steering..
PS I now check the QR every time. I think I'll have a sticker made up.
my build mac1motorsports
posted on 25/9/09 at 12:58 PM Reply With Quote
Mac1motorsports WorxZX10R
should have gone CEC
or eat more pies.
MakeEverything
posted on 25/9/09 at 01:03 PM Reply With Quote
or eat more pies.
Lol,
Sounds symbolic of a lightweight car with an underweight engine. As said, you only really get a good feel with more weight physically - ie a car engine.
Kindest Regards,
Richard.
posted on 25/9/09 at 01:04 PM Reply With Quote
Try lowering the front ride height. Front end lift can be due to the front of the car riding higher than the rear so air gets rammed under the car and lifts the nose, making the steering light....
posted on 25/9/09 at 01:14 PM Reply With Quote
Classic symptom of toe-out
Could be you are getting extra toe-out due to bumpsteer as the front end lifts. Dial in a bit more toe-in and try it.
Ben_Copeland
posted on 25/9/09 at 05:09 PM Reply With Quote
You can lower the tyre pressures as well. Most run 14-16psi i believe.
I had similar problem till i had my tracking done. got about 1/2degree toe out and it felt fantastic after
Ben
Locost Map on Google Maps
Enter Your Details Here
steve m
posted on 25/9/09 at 05:43 PM Reply With Quote
!6 PSi in mine
when it was 28-32 it was like driving with the steering disconected !!
Flamez
posted on 25/9/09 at 06:15 PM Reply With Quote
Thanks guys I'll get the tracking sorted and try lower tyre pressures.
posted on 25/9/09 at 06:18 PM Reply With Quote
They are light cars and very responsive, but should be stable at speed. As said above :
* Rear ride height greater than the front, by about 1" - 25mm (measure from chassis to floor - but not where the rear rises up!)
* Front wheels set parallel or slight toe-in.
* Tyre pressures not too high - mine are 18psi, most people run 20psi or below.
Easy things to play with, and should give a nicer feel.
grusks2
posted on 25/9/09 at 07:21 PM Reply With Quote
Phill
I run my front at 95mm at the front, measured at the chassis front, and 115mm at the rear measured at the rear of the chassis by the floor pan.
My steering is the same as yours 8 threads either side, measuring with a tape measure, 2 parallel lines down the side of the car, ive 4mm toe in either side. Shocks are 8 clicks at the front
My tyres are at 17psi but filled with nitrogoen
My car goes a bit light at about 90+ in a straight line, but im happy with it.
http://mac1worxbuild.wordpress.com/
forgot my old password so another username doh
grusks2
posted on 25/9/09 at 07:22 PM Reply With Quote
what about some of those carbon mods front nose cone downforce winglet bits.....?
DarrenW
posted on 26/9/09 at 10:20 PM Reply With Quote
Try slowing down. Your not on the way to a fire any more now Never had that problem in mine (although a pinto engine and driving like a granny might have a part to play!!!).
Flamez
posted on 29/9/09 at 11:40 AM Reply With Quote
Originally posted by grusks2
Phill
Thanks spence
I have lowered the front to 110 front and 140 rear. I'm not keen to go much lower for now as I need the clearance to get on and off the drive. I have stiffened the dampers upto 8 clicks too. With tyres remaining at 20psi. It now feels a whole lot better at speed.
Pleas let me know if you ever get a soln. for the full cage without taking panels or the floor off.
