Latest Acewell digital dashes
The 5XXX series has been around for a few months now, but Acewell have just introduced a new one to the range - the 5859, pictured, comes in black as
standard, silver fascia is available. £197.98 (less discount to Locostbuilders), it does Speed, revs (graphic & digital), fuel, temp, gear
selected, clock, mileage trips, shift light, over temp light etc etc plus gives all the warning lights built in that you need for IVA & no sharp
edges to upset the radius check! For an additional £19.99 you can add a wired remote control which enables the 99 lap, lap timer feature, a serious
dash at a competitive price
  Ace 5859
Also just arrived the Very latest 6556 dash pictured below. These have an analogue needle for the tachometer which are available as 0-9000, 0 - 12000
or 0 - 15000 (preset at the factory). I only have a very limited stock of the 0 -12000 units only at present, other units should be available in a
couple of weeks. Functions are very similar to the 5xxx unit above with
Speed, revs (analogue & digital), fuel, temp, gear selected, clock, mileage trips, shift light, over temp light etc etc Has a large 12mm shift
light, but doesn't have warning lights. Price is £228.99 before discount
  Ace 6XXX
