New Topic New Reply
Author: Subject: Gas/Gasless Mig Welder.
arcwelding01
posted on 10/12/10 at 01:31 PM Reply With Quote
The GYS Universal 2P is a dual purpose welding machine able to use standard mig wire with a gas shield or as a gasless welder using self shielding Flux Cored Wire, ideal for use outside.
Wire Diameter: 0.6mm to 0.8mm with gas or 0.8mm to 0.9mm in gasless.
Duty Cycle: 15% at 115amps, 60% at 55amps, 100% at 45amps
Power Range: 45-150amps
Input Voltage: 240v
Dimentions: 34 x 59 x 43 cm
Wieght: 28kg
[size=5]
£315.00 Inc Vat & Carriage
[/size]
New Topic New Reply
