Optimum Balance Products
| posted on 4/3/08 at 11:20 PM |
AP £700 - obp Ltd £150 A Bit Of A No Brainer
Hyd or Cable Clutch Universal Reverse Master Cylinder Cockpit Fit
3 Pedal Floor Mounted Pedal Box (Made in England)
Perfect For Subaru, Evo, Mazda, Ford and Most Production or Race Cars
Check it out at our ebay shop:
http://cgi.ebay.co.uk/Race-Performance-Cockpit-Fit-3-Pedal-Hyd-Floor-Mounted_W0QQitemZ190202424141QQihZ009QQcategoryZ23013QQtcZphotoQQcmdZViewItemQQ_t
rksidZp1742.m153.l1262
Soon we will have a full range on our new web www.obp.uk.net
The equivalent by AP will cost you a minimum of £700 plus VAT.
Ours start at £164.50 Inc VAT. This not due to the quality of the product, we manufacture these items so no middle men and you get the price benefits.
We want to offer you a top quality product at a fair price.
Our light weight range of floor mounted pedal boxes are designed to offer the driver the highest level of efficiency in this critical area.
The ergonomic design of our fabricated pedals, together with low friction high quality oil impregnated spherical bearings set new standards in pedal
box design and operation.
This unique push type cockpit fit design, allows the pedal box to totally fit within the driver cockpit. No need to drill any holes in the
bulkhead.
This fantastic design is by far the easiest multi universal fit pedal box on the market.
The cylinders are mounted under the driver’s feet for optimum space utilisation and access for fast pit repairs.
This cockpit fit pedal box assembly is designed to provide car builders and race teams with an all-inclusive system that has fully adjustable brakes,
very simple installation and is easy to service. This pedal box is used with a bias bar system and dual master cylinders, allowing you to have a fully
adjustable twin braking system. These floor mounted units can be fitted into all types of cars from race cars, hot rods, kit cars, performance cars,
classic cars, etc. It is a very versatile system. The ergonomic design & efficient action of the assembly provides feedback that inspires driver
confidence, helping produce faster lap times.
The pedals pivot on oil impregnated bearings, giving you low maintenance long lasting and smooth operation.
Obp Ltd offers you top quality professionally manufactured products. Our ethos is to supply you the best products possible. Delivering long lasting,
incredible quality that looks and feels great. Due to this ethos our products will make any build or upgrade you undertake a more pleasurable
experience.
Pedal Box Dimensions: Width 240mm, Depth Inc Master Cylinders 260mm, Max Pedal Height 280mm, Max Box Body Height 70mm
Aluminium Top Cover Dimensions: Depth 300mm, Width 270mm
Pedal Ratio: 5:1
(All Dimensions Approx)
Kit Contents: 1 x Pedal Box Frame, 3 x Pedals, 1 x Bias Bar, 3 x Master Cylinders, 1 x Aluminium Top Cover, 6 x 8mm Nuts & Bolts, 1 x Clevis
Cost For This Kit: £309.92 Inc VAT (Equivalent by AP well over £1,100)
Thank you for your time, we hope to hear from you very soon.
All our contact details are at the bottom of the page.
Regards
The obp Team
Optimum Balance Products Ltd specialise in floor mounted and top mounted pedal boxes. We also manufacture many other products and can under take one
off alloy fuel tanks or other design projects. Please contact us via email to sales@obpltd.com or have a look at our fantastic ecommerce web site
www.obpltd.com
Thank you for your time.
All the best,
Obp Ltd.
