I have a choice of a live axle or an IRS chassis
What are the pro's and cons of both ,It will have a bike engine for a power unit
Mainly i will be using the car for fun on the road
Personally I would go for irs rear axle have had both and still have a bec with irs for hills much more progressive rear end and better range of diffs if you decide to go for 1000cbrr type engine 3.54 is lowest in a live axle and no use for 1000cbrr type engine
Ultimately IRS will be better however, a badly setup IRS car will try and kill you at every corner whereas a Live Axle car can't really be badly
setup.
I remember speaking to someone who prepped a lot of customers kits for IVA/did work on them and he said he always dreaded the first test drive in a
IRS car which a customer had built as he never knew what is was going to do, he was quite happy to jump in a live-axle car because they always did
pretty much what they were meant to.
I aimed for the best of both......De-dion.
My experience of them is that the IRS rides & handles better (if its been set up correctly) but if your chasing weight reduction then go live
axle
That said, iv'e been in live axle cars that handle really well
Depends what your aiming for really, I'd of thought for a bec you'll be aiming for as low an overall weight as possible?
Live axle for me. I've had BEC live, BEC IRS, CEC live and CEC IRS cars before. It's the weight that makes the difference IMO, around 50-60kg by my reckoning.
For those recommending live axle, it's worth re-iterating Richard's point above, that you'll be limited on gearing (and even 3.54 and
3.77 English axles were like hen's teeth, last time I looked... although you can buy the CWP's from people like Burton).
One of the things I dislike about BECs for road use is that the gearing is almost always too short - the constant high cruising revs grate on my
nerves. This may not bother you, but bear in mind that with a live axle you'll be looking a very under-geared 'screamer'.
IRS
as some of the others say you can get the diff ratio low enough
I had a Sylva Phoenix with a 919 carb'ed fireblade engine and a I think it was 3.08 : 1 diff out of a diesel sierra the gearing was great. I
could drive it smoothly around the streets and race it in the RGB plus I managed 130 mph flat out (once only just to see)
Plus it accelerated well.
I loved that car and still not sure why I sold it.
PS
I've had a fisher fury with cross flow and live axle, and now have a locost with cross flow and live axle.
I think the handling is good with either IRS or Live with the IRS being a bit more of a supple ride.
With the IRS you have the option of adjusting the rear TOE to your taste
For road riding irs is much better. My westfield live axle used to move around on roads with a camber.
Track wise my westfield was great handling and never felt different from my Avon irs.
That said for resale irs gets more normally. Especially in westfield cars.
Hope that helps.
3.54 diff isn't that rare (if anyone wants a genuine Ford CWP set for £220 give me a shout) and with a CBR1000 and 205/60r13 or 195/50r15 tyres
gives about 128mph top end, perfect IMO. Wind noise is louder than engine at motorway cruise anyway!
[Edited on 21/10/18 by AdamR20]
How do i find out what diff i have got as i have a cosworth sierra diff and an english axle, can i find out without taking them apart
You can do it by carefully rolling the car forwards and counting revolutions of the propshaft to revolutions of the road wheels.
Don't try to do it by jacking the car and rotating the wheels, though, as if you have an open diff it will give false results
Edited to add: if it's just diffs/axles, and there are no tags or markings, you can do the same thing by counting turns of the input and output
shafts, but make sure that both output shafts turn exactly the same number of revolutions.
[Edited on 21/10/18 by Sam_68]
Sam both live anxle and cosy diff are out of the car as i haven't started to build it yet
Sorry, yes... just realised that and edited my post above.
... and it's not that big a deal to take the backplate off a Sierra diff and count the teeth on the CWP, of course.
Bit more of a pain with the English axle, as you need to extract the driveshafts first, but you can still do it without upsetting the clearance on the
CWP, which is the main thing to worry about .
Thanks Sam
I have had a live axle Striker and now an IRS Striker. The IRS is setup sensibly with the proper equipment and so much better to drive on the roads
than the live axle ever was. Its much more stable over changing road conditions, pot holes, leaf debris etc. Go IRS IMHO
