motorcyle brakes
hellier0437 - 18/8/07 at 07:40 PM
just wondering whether anyone has explored the possibility of using a motorcycle brake master cylinder or two for the brakes? as i have been warned that using vacuum brakes in a light car could cause it to lock up too easily and the only non assisted cylinders that i can find are expensive
just a thought
thanks for any help
big_wasa - 18/8/07 at 07:44 PM
Just remove the servo and use the car Mc with a push rod
[Edited on 18/8/07 by big_wasa]
RazMan - 18/8/07 at 09:48 PM
A servo is definitely overkill on such a light car imo. Why would you use a m/c which was designed for hand use anyway? Girling or Wilwood - designed for the job
[Edited on 18-8-07 by RazMan]
Trev Borg - 18/8/07 at 11:00 PM
How about a pair of motorbike front calipers tho'.
You can pick up some nice cheap light weight one.
Just a thought
Shoot me down now
froggy - 19/8/07 at 09:02 AM
im going to use bike calipers on the front of my kitten ,ive seeen them on grasstrack cars and i think that some stuart taylor cars use them up front too
Peteff - 19/8/07 at 09:14 AM
He's thinking of using the M/Cs from a bike so unless he used the callipers to go with them I doubt if they will be big enough for car brakes. To use bike callipers you will need bike disks or callipers spaced to take car disks which are about 3 times thicker.
froggy - 19/8/07 at 02:18 PM
i meant id seen a locost using bike discs and calipers up front ,sure it was a st of some sort.
hellier0437 - 19/8/07 at 10:59 PM
thanks for the help, will go down the car designed route
bikenuts - 20/8/07 at 03:49 PM
Bigest problem with most bike calipers is the pipe usualy attaches to the outside of the caliper making them dificult to package unless you've got large diameter wheels - which weigh more and defeat the object.
ChrisGamlin - 24/8/07 at 12:31 PM
What do you mean by expensive when mentioning that you cant find manual servos cheaply? You can get Wilwood master cylinders for about £25 from Rally Design etc, a pair of those with a bias bar and you're sorted
