Quick question for you turbo experts.
What is happening to my boost. I get some boost as low as 2300rpm, it peaks at 7krpm, where the boost controller is encouraging decent boost. Then
the boost gradually drops off with RPM. Is this expected? What is the mechanism?
I guess it is exhaust gas pressure pushing open the wastegate, but I'd like confirmation. I had the opposite phenomenon before, so opened up the
gas path to the wastegate (and the hole itself) a little.
My plan is to tweak the boost duty cycle at higher RPM to level off the boost (this can be controlled with megasquirt). Note that the controller is
inverted, i.e. 100% means don't bleed off any boost so it should just be based on the spring. Any (helpful) comments appreciated.
At the moment its a bit rich at the top end (aiming for a safe 11.5) and so I think I can get 8psi at 11kRPM without going over the duty cycle limits
of the injectors (s2000) at the present (3.25bar) fuel pressure. No idea on power, but its using a lot of fuel which must be a good sign
It
certainly feels quite nippy
Matt
Looks like where you have 'dipped' the throttle, it has opened the wastegate and is bleeding, hence the decline after the 'dipped'
TPS reading.
Boost so early on suggests an undersized turbo, but less lag. If you have enough top end, then i would leave it.
The other thing i would try and look at is a bleed valve for the wastegate, to try and adjust the actuator.
can you clarify, with that turbo have you been able to maintain the boost at higher revs? if so, what did you do to it?
Originally posted by matt_gsxr
I guess it is exhaust gas pressure pushing open the wastegate, but I'd like confirmation. I had the opposite phenomenon before, so opened up the gas path to the wastegate (and the hole itself) a little.
Originally posted by MakeEverything
Looks like where you have 'dipped' the throttle, it has opened the wastegate and is bleeding, hence the decline after the 'dipped' TPS reading.
It is strange the boost doesn't plateau but actually drops untill you cycle the throttle - something that doesn't tie up with the wastegate
bleed. Perhaps it's the gas flow at the intake to the wastegate upsetting the rest of the flow to the turbo? Perhaps rounding the wastegate inlet
would help?
James
Also, that said - the earlier graph you posted doesn't get to the same boost even after creep as the one with the problem, perhaps you are only
now seeing the limits of the turbo?
James
Originally posted by cloudy
It is strange the boost doesn't plateau but actually drops untill you cycle the throttle - something that doesn't tie up with the wastegate bleed. Perhaps it's the gas flow at the intake to the wastegate upsetting the rest of the flow to the turbo? Perhaps rounding the wastegate inlet would help?
James
Also, that said - the earlier graph you posted doesn't get to the same boost even after creep as the one with the problem, perhaps you are only now seeing the limits of the turbo?
James
I meant the graph pre wastegate mod...
James
James
Oh, here is a plot of the flow and pressure from the same log onto the compressor map.
Looks like it is pointing nicely towards a Pressure Ratio of 2.0 at decent efficiency.
Probably just need to be a bit braver and stiffen up the wastegate spring.
Surely this would be expected since you are swapping between two different modes of operation? To start with you have a boost controller actively
controlling the wastegate to achieve a target boost level, which you then effectively disable at 7000RPM (why?) and leave the wastegate actuator to
look after things.
Using only the wastegate actuator spring to control boost rarely gives good results. In effect you have a control system where the wastegate actuator
provides an output movement which is proportional to boost pressure, but the wastegate itself will have a highly non-linear response that will depend
on numerous factors including engine RPM and load. A control system with only proportional feedback will always have a residual error term which
depends on the closed loop gain, and if that gain varies with RPM then so will your residual error.
Porting the wastegate will have the same effect as a large throttle body, i.e. most of the action happens in a smaller range of motion, making the
non-linearity worse. IMO the best solution will be to keep the electronic boost controller operating.
EDIT: Are you logging the boost pressure at the same point the wastegate is connected to?
[Edited on 27/9/11 by MikeRJ]
Thanks Mike,
I'm disabling the boost control at 7000rpm, because I had no idea how stiff my wastegate helper spring was, so didn't want the boost to go
too high.
Yes the pressure being logged is the same as is being fed towards the wastegate (but before the boost controller, so the wastegate will see less
pressure if the boost control is being used).
Thanks for your comments, very reassuring that the behaviour makes sense to you.
Matt
