How the hell am i supposed to fit my sender into my tank. The insructions say it should bolt from the inside but thats never happening, unless i get
my 11 month old to stick her hand into the hole, snap her elbow through 180 degrees and work a ratchet blind.
Can i use self tappers and a silkaflex type sealant???
Rivnuts? Or have a boss welded on that is tapped. I did both on my tank... Rivnuts for the in tank pump and a welded boss for the sender....
Dave B
Ali rivnuts for me.
Couple of pics here which may help.
Fuel Sender
Tank
i made a ring for inside the tank then tapped the holes in the ring, screwed bolts in then passed them up from inside the tank, this left a ring of captive studs sticking up thru the tank for me to fit nuts on the top side
