is there a way of getting a zetec sparking with scrapyard parts because ive just bought some bike carbs adam
ps. iam a tight arse lol
not done it yet myself...
http://www.toyne.org.uk/zetec.html
Have done it
You will need to attach a vacuume feed to the carbs. Easier said than done on bike carbs.
It will run but not give an ideal level of ignition advance for a tuned engine.
See http://www.youtube.com/watch?v=mwc6KwyhZ6g
[Edited on 10/6/07 by big_wasa]
When I had problems getting my car through the SVA test on FI I converted to Weber carbs and passed running the ignition on just an Edis unit. This
operates the engine at a fixed 10 degee advance, but thr car would still do 80 mph.
I thing the control unit in the above reply, with a vacuum connection is an ECU from a 1.3 Escort of circa 1990, and may give variable ignition
advance, as well as load sensing.
Mal
Originally posted by big_wasa
Have done it![]()
yes fitted to escorts and fiestas ect. It does in deed alter the advance with the load of the engine.
As cheap as it gets.
if it runs ok ill leave it on. it will last longer then the engine anyway lol
adam
do you have a wiring diagram for it
adam
you have u2
you have u2
if you get stuck send me the loom and Ill alter it for you..
Dont think so some how..
Seeing your other handy work
you want to be looking on the near side wing and the back of the bulk head and you want the red and black esc as in my pic.
thanks ill take off as much as i can then ill sort it out after
adam
