I've just had the feed pipe banjo connector off my plastic tank and now its leaking. The moulded-in nut is loose in the tank. Any ideas of a
solution short of a shiney new alloy tank?
Adrian
Can you epxoy it back in?
Pat...
It's not come out; Just moving very slightly in the plastic and fuel's leaking past it.
Adrian
I have had the same problem, plastic tank which KitCarWorkshop and Car Solutions? used to supply. Presumably yours is a Fury, mine is in a Striker. I
used some heavy gasket paper from the motor factors, then a washer, then the banjo. I think that was it and it has not leaked since. If I remember
rightly, the washer has got to be fairly thin as there are not too many threads on the banjo.
If you struggle let me know and I'll post you a piece.
Cheers, thats exactly what I was thinking of doing. Good to know it works.
Adrian
