bike carb slide flutter
triumphdave - 16/6/07 at 01:04 PM
I seem to be getting a serious flutter from no.2 carb from the slide on decceleration its quite bad I thought it was a body panel originaly.It doesnt seem to have any more play than the other three anybody any ideas.I dont know if this is related but the same carb seems to pop occasionaly,it did this when running webbers also
triumphdave - 16/6/07 at 01:40 PM
Originally posted by robocog
have they been balanced?
Yes
triumphdave - 17/6/07 at 09:04 AM
maybe worth checking that the top diaphragm isnt split and is seated properly?
An air leak could cause the spit/pop out of just one? but I think a balancing session would show this up?
perhaps a float that is jamming shut or fuel way cruddied up?
Have you got a colourtune glass spark plug ?
If it did this with different carbs also could it be a valve sticking?
Maybe worth looking at the spark plugs, have a spare set ready if your anything like me removing them
Thanks robocoq
The diaphragms are fine,also the floats,I have also changed the plugs.Its looking more like what we both suspect a valve.I was hoping somebody would come up with something simpler.I was not looking at any more major surgery untill the winter.
triumphdave - 17/6/07 at 11:51 AM
Mines the 1600i,solid lifters,but dont get discouraged all ideas are welcome.
