Hi all,
After spending quite a long time sorting out various aspects of the wiring I now have a car that starts but doesn't idle YET!
I was wondering if anyone with a similar set-up to me could kindly donate a map.
Just bought a LC1 so I will be tuning it too but could really do with a starting point or at least a reference.
Setup as follows:
2.0L Zetec - standard internals
GSXR 1000 (same as 750) Throttle Bodies
LC-1 Wideband sensor installed - sorting integration into MS atm.
EDIS ignition
Any help appreciated I will probably start from scratch but something for reference would be really useful.
Thanks!
Doh.... charliewallis@hotmail.com
Try here in the downloads.http://www.extraefi.co.uk/downloads.htm
Lots of maps and good info on there that will give you a starting point, but you will need to do a lot of tuning no matter what you use , i havent
found a good one that works from scratch yet.
Paul.
Been working on it tonight using the map I was given ages ago. Just cannot get it to Idle...
It starts every time but then it slowly slows down and dies. Tried messing around with warm up enrichments etc. But no joy.
LC-1 also showing voltage despite having AFR checked as prefered...
Quite frustrated and concerned that my plans for finishing it this summer are pie in the sky
Someone remind me of way I turned down a set of 45s (jetted correctly) and a fully mapped system including loom for my engine...
Must stay positive
Pm me your email address and i will send you my msq im using the same set up with 1800 zetec injectors.
Some obvious questions to check.
- What version of MS are you using?
- Have you calibrated you AFR table? Look under tools in Megatune?
- In Megatune configurator have you selected and LC-1 and said to use AFR and not Lambda?
- Is EGO control active at idle? If is and you are seeing something other than AFR it'll mess it up.
Where are you?
[Edited on 19/8/07 by chriscook]
Thanks Mr Zetec for the Map. I've had no chance to try it yet as have been felling trees all weekend (right outside the garage).
Thanks also Chris for the reply...
I'm on MSI V3
AFR Targets Table under "More Settings" is not setup properly.
Ego Control is only set to be active above 7500rpm (I can't get to 1500
Config is set to LC-1 0-5v 10-20 AFR
Display Lambda is un-checked...
I'm in sunny (ha ha) Glucestershire!
One thing I've been thinking on is maybe my Fuel Req is way off. I haven't checked the Pressure (supposed to be 3bar pre-set) Will get a
gauge from merlin on way home tomorrow.
Thanks for the replies very encourgaing to know I'm not on my own
Will post how I get one tomorrow!
Charlie
Will definitely post up how I get once I can get on with it... Bought a gauge and it cracked the casting of the fuel reg when screwing it in. So
awaiting new one...
Been trying to get the LC-1 to comunicate with the laptop and its not playing ball. It connected once very briefly but lost connection when I tried to
program it and nothing since.
Didn't want ppl to think I'd just got it working and hadn't bothered to respond. Seems a lot of thread end up like that...
These
things are sent to test us...
OK little update. I have completely started again with the MS and loaded new firmware on and used Mr Zefects map to get the car successfully started.
Fuel pressure adjusted to 3bar engine revs up and idles but with slight throttle.
Next problem: Looking at real time data the MAP signal is sat at 90kPa. Should this not reduce significantly with throttle almost closed. I have
removed the vac take off and I can get it to go down by sucking on it...
Its plumbed into the manifold through the channel in the gasket to get a reading from all TBs. When the engines running I can't feel any suction
on this though.
Does this imply a leak?
Thanks for all help so far until this weekend I had started looking for Webbers and ECUs
Now feel slightly back on track!
C
