i just bought a sierra as a doner car for my mk indy build and was wonderin is it possible to change my 2lt pinto from fuel injection over to
carbs??
[Edited on 1/5/08 by ryland06]
put a carb inlet manifold and carb on,get a fuel pump and push rod,job done.
the bottom of the inlet ports are a bit close to the outside of the gasket but it never caused me a problem
the bottom of the inlet ports are a bit close to the outside of the gasket but it never caused me a problem![]()
I would suggest Bike carbs for improved performance
Erm not wanting to pi** in anyone chips and all but.....
you might find that a manifold for a set of carb's may or may not fit on to the injection head as the inlet manifold's for carb and
injection are different, also the injection head has extra pockets cut into it for the injectors fuel spray from the manifold.
[Edited on 1-5-08 by Dragon-Performance-Eu]
thats why i mentioned the bit about the gasket,never had a problem with that and get your own chips if you want to do that sort of thing
thats why i mentioned the bit about the gasket,never had a problem with that and get your own chips if you want to do that sort of thing![]()
I'm on the look out for a cheap Sierra Pinto EFI intake manifold (complete) to butcher up if your's is surplus to requirements.
you might find that a manifold for a set of carb's may or may not fit on to the injection head as the inlet manifold's for carb and injection are different, also the injection head has extra pockets cut into it for the injectors fuel spray from the manifold.
i had a air leak so i got my mate to make a plate to cove the holes for me
i put an injection gasket on the plate then the carb gasket with the bike carbs works a treat
Originally posted by mat.price
i had a air leak so i got my mate to make a plate to cove the holes for me![]()
i put an injection gasket on the plate then the carb gasket with the bike carbs works a treat![]()
Use a cheap pattern carb gasket and it is usually ok. the real ford gaskets are a bit thin in the top area.
i got a gasket form burton power that was quit strong and thick that might do the job for you
https://www.burtonpower.com/product_main.aspx?prodLanding.aspx?CCode=PC090
