Hello
Playing around with the autotune feature, all set up for wideband and plugged in my JAW, turn on and the mixture adjusts so all good, only thing is
the megasquirt display.
The dial only runs to 1v, it needs to show up to 5v. Any tricks to correct this anomoly? The enrichments are set to wideband etc. The values in the
tab are correct, second one down, left hand side.
Cheers Mark
Got it, set the ini to LC1 to match the JAW Vout
The version is 2.25p1, defaults as EGO on mine.
Its 2.2 board, squirt only, built it years ago.
Will have another go later in the week.
Cheers Mark
