the_big_1
| posted on 7/3/17 at 09:03 AM |
Black top system
Hi guys,
I have a bare silver top Zetec. There is a black top ecu and all keys etc, would this work on my silver top??
http://www.locostbuilders.co.uk/forum/34/viewthread.php?tid=208003
chris
| posted on 7/3/17 at 09:11 AM |
The only difference between black top and silver top is tappets and water pump so any electronics between the two should work
Ugg10
| posted on 7/3/17 at 09:53 AM |
Iirc you also need the right injectors and maf to go with the ecu and also a lambda sensor in the exhaust. I could be wrong though and they are
interchangeable but had problems between swapping 1800 and 2000 silvertop parts before.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
the_big_1
| posted on 7/3/17 at 09:56 AM |
Cheers guys. I have a brand new inlet manifold off a black top that has the injectors etc
| posted on 7/3/17 at 11:15 AM |
Silverton engine sensors don't work with blacktop ecu either, you'll need to change all the electronics over.
the_big_1
| posted on 7/3/17 at 11:17 AM |
Only ones would be crank and cam sensors?
| posted on 7/3/17 at 11:21 AM |
Crank, cam temp and as said all the bits on the inlet which you already have...
the_big_1
| posted on 7/3/17 at 11:24 AM |
Sounds good to me. Sensors should be fine to get online.
