blockhead_rich
| posted on 25/2/06 at 06:32 PM |
What's this do - GSXr 600 T/B Question
Hi
I have a set of GSXr 600 throttle bodies and I'm not too sure what the rubber pipes and sensor do. Wondered if they are still of use with
Megasquirt?
  T/B's # 6
Sorry about he poor image of the sensor!
  T/B's # 7
[img][/img]
Thanks in advance, seem to have lots of questions that need answers at the moment
Rich
COREdevelopments
| posted on 25/2/06 at 06:52 PM |
hey rich
looks like map sensor to me. do the pipes all connect to one pipe that goes to the back of the sensor? if they do it should be your map (manifold
absolute pressure)
hope this helps
Confused but excited.
| posted on 25/2/06 at 08:02 PM |
The set that I have just bought have the pipes commoned and the common ends in a doohicky with a three pin socket on it. So I am also assuming that
this is the map sensor.
BKLOCO
| posted on 25/2/06 at 08:24 PM |
Yep looks like MAP sensor to me.
For MS I'd just rip it off and run a pipe from the las "T" to the MS MAP sensor as we discussed earlier.
blockhead_rich
| posted on 26/2/06 at 08:05 AM |
Thanks Guys that's helped a lot/ Oh and thanks for the coffee yesterday Brian!
So one more question then!
  T/B's # 10
Rich
BKLOCO
| posted on 26/2/06 at 09:06 AM |
I think I'd blank it.
Anything you connect to just one TB will pulse.
Brian
striker4age
| posted on 27/2/06 at 03:48 PM |
Blank it, as it's on the engine side of the throttle plates you would never be able to balance the throttles, (I'm still not too sure how
or if you have two as they are all linked by the tube that goes to the MAP sensor.)
By the way, I'm in the very slow process of putting a set of GSXR 600 bodies onto my 4AGE (big port) using a custom manifold but an Emerald for
an ECU. I won't have Idle control, and didn't have on the old set up.
