Mansfield
| posted on 10/3/06 at 06:55 PM |
Megajolt CVH with sized photos
I have a 1.6 CFi CVH engine that I recently aquired for next to nothing, an intend using it for my Locost.
I have been playing email tennis with Bill Shurvinton about using a Megajolt and how it would integrate with the current Ford setup. Bill's
communication is faultless and quick. Its almost like he is sitting waiting for my next stupid email.
Seems I can use my existing coil pack/edis4/VR sensor AND the 'teeth' (see photo) cast into the back of my flywheel to feed the Megajolt.
Cost wise - £20 board & CPU, £100 Fully built and tested in a housing and £80 kit 'n' case unbuilt.
I have seen £35 as a cost of Megajolt on this forum and a website showing Avon + Pinto installation. Can I build one for £35 and where would I get the
necessaries?
Thanks, David.
Mansfield
| posted on 10/3/06 at 06:57 PM |
And here is the missing tooth.
big_wasa
| posted on 10/3/06 at 07:25 PM |
No chance can you buid one for that money.
£100 is not a bad deal if it incluedes map sensor.
The problem is with minimum quantity ordering of some parts.
I priced it and found it cheaper to buy one ready made. imho
Mansfield
| posted on 10/3/06 at 07:41 PM |
Quotes from emails
The board and CPU are £20 A fully built V3 cased and tested is £100
and
Everything you need for TPS based system, including case is £80
Unqotes from emails.
Dont think it includes the MAP sensor.
paulf
| posted on 10/3/06 at 09:10 PM |
I have supplied fully built V3 units for £75 set up for TPS and fitted in an alloy case complete with set up software and connector plug.Unfortunately
I am waiting for PCBs which i orderd from a UK supplier as they were out of stock in states and was then told he is out of stock also. I presently
have a number of people waiting for me to build them units but
when I eventually get them i will be able to supply for a similiar price but dont know when it will be at present.
Paul.
[Edited on 10/3/06 by paulf]
Deckman001
| posted on 10/3/06 at 09:17 PM |
Paul if you need a pcb suppier let me know before Monday, I'm off up to brum then and will be poping into our pcb supplier they also make
chargers for the US military and RS components if you need any recomendations !!
Jason
