Hammerhead
| posted on 17/10/06 at 08:11 PM |
Braided fuel hose
Hi guys,
If I get some braided fuel hose to connect the fuel tank to the FI system on my k series, will it pass SVA? Does the hose have to have 'Fuel
use' or whatever printed on it? or will a receipt sayinf it's fuel hose be ok?
oliwb
| posted on 17/10/06 at 08:15 PM |
You just need to have proof that its suitable. Doesn't matter if the proof is printed on the side of the hose or if your receipt has it written
on....could probably even be like a mail order internet page printout with a picture of the hose along side the description....As long as you can
prove it....Oli.
randydoc
| posted on 17/10/06 at 10:10 PM |
Nitrile Rubber hose is fine so long as you do not run it inside an enclosed cockpit as it allows fuel vapour to seep through it over time. You must
use a hose with a PTFE liner if routing inside an enclosed cockpit. Hope this helps.
