Nitrogeno25
| posted on 5/7/12 at 06:30 PM |
Throttle bodies - alpha-N driveability
I'm finishing my install with the Duratec with Jenvey 45 TBs. Running megasquirt in pure alpha-n mode as the jenvey does no provide a take off
for vacuum.
I'm a little concern about driveability at low load, when everybody said that driveability suffer with TBs, can we compare it with a carburate
car, for example?
Thanks!
mark chandler
| posted on 5/7/12 at 06:48 PM |
All that happens is that a very small throttle opening lets in a lot of air making the pedal very sensitive.
Have a progressive cam so large movements at the pedal relate to small throttle openings and you remove this issue.
For a vacumn take off use some LPG fittings, drill and tap the manifold and run rubber hose (stuff that will not collaspe under vacumn) into a 4:1
joiner and take this off to the MAP sensor.
Regards Mark
GeoffT
| posted on 5/7/12 at 07:37 PM |
For the same reason you'll find that a small change in throttle off idle will need a large change in fuelling (VE) - it helps if you keep the
TPS bins very close together at the low throttle part of the fuel map, maybe just one tps count apart.
Nitrogeno25
| posted on 5/7/12 at 07:55 PM |
Regards Mark
I'm not sure how I feel about drilling the j$e$n$ve$s direct to head TBs.
matt_gsxr
| posted on 5/7/12 at 07:59 PM |
Put in some closely spaced load sites around the closed throttle.
As long as you balance them then you will be fine.
GeoffT
| posted on 5/7/12 at 08:05 PM |
.......Mark said drill and tap the manifold , your first post did not say they were direct to head........!!
Nitrogeno25
| posted on 6/7/12 at 01:34 AM |
You're right, sorry for that!
jeffw
| posted on 6/7/12 at 05:18 AM |
for vacuum.
car, for example?
Thanks!
I've used Jenvey TBs on both Megasquirt and Omex and have never had a 'driveability' issue with alpha-n. Bike throttle bodies yes,
Jenvey no.
BaileyPerformance
| posted on 9/7/12 at 12:21 PM |
for vacuum.
car, for example?
Thanks!
Alpha N is the only way to go with throttle bodies, using speed density (MAP) is worse as you end up with a big vacuum change with small throttle
opening changes.
So no need to drill your throttle bodies, just set up for Alpha N and you'll be spot on!
Cheers Dale.
Nitrogeno25
| posted on 17/10/12 at 09:13 PM |
Many thanks for your replies.
I try to balance the TB as good as I can, but with the bleed screws fully closed (as recommended by Jenvey) I get these readings (Cyl 1-4): 3.5, 4.2,
4.2, 3.5 Kg/h.
If can adjust to almost perfect balance using the bleed screws and the idle gets better too. I'm I doing something wrong?
Many thanks again!
stevebubs
| posted on 17/10/12 at 09:57 PM |
Don't know much about the Jenveys in question but are there not screw adjusters on the linkages that should probably be set first?
Nitrogeno25
| posted on 17/10/12 at 10:00 PM |
There is one adjuster between each par of TBs. I'm using DTH. Thanks!
