tim windmill
| posted on 27/8/07 at 04:02 PM |
injector flow rate
Trying to set up my megasquirt and i need to know the flow rate of the standard 2.0l blacktop injectors , they are white if that helps at all. i am
using the griffin inlet manifold with standard throttle body and fuel rail. Any mapping help and base set up appreciated
| posted on 27/8/07 at 04:10 PM |
Most injectors have a serial code on them. You can use that to look up the flow rate online. Try googling for "Stan Weiss injector table".
chriscook
| posted on 27/8/07 at 08:39 PM |
Depending on the firmware you are running in the MS you may be able to run an injector test to measure the flow yourself - have a look through the
menus in Megatune
Dusty
| posted on 27/8/07 at 09:00 PM |
192cc/min at 3 bar.
