Namyllegin
| posted on 6/11/08 at 08:58 PM |
Bosch K Jetronic Fuel Injectin
Hiya,
Wonder if anyone has a K Jetronic system or knows the plumbing on one. I have one of a V6 Cologne engine and I have most likely got some of the hoses
misplaced. All the injectors are connected correctly, it's the pipes running to the Cold Start Injectors / Warm up regulator etc that I have
buggered up.
So if anyone knows how I can plumb one of these up that would be great.
Thanks in advance
Nige
Mr G
| posted on 6/11/08 at 10:17 PM |
I've got a 4i as my daily driver - I pressume you hav'nt got the sierra v6 manual and as a picture says as thousand words -
(Click to Enlarge)
CLICKY
CLICKY
(20) Warm Up Regulator
(22) Auxilary Air Device
(24) Heater Feed Hose
(35) Fuel Start Valve
Am back up working on the old girl tomorrow morning so will note down where the ins/outs on the metering unit for the warm up reg and the fuel start
valve are. Sure the return feed from the warm up regulator goes onto the centre banjo on the fuel distributor.
Will clarify tomorrow
G
[Edited on 6/11/08 by Mr G]
Mr G
| posted on 7/11/08 at 05:06 PM |
Looking down onto the metering unit from the front the connections are as follows :
(On the side of the unit closest to the engine)
Warm up regulator (Left) ----------o
Fuel return to tank -------------------O
Double banjo from single outlet- oO
Feed to Fuel Start valve _______l l
Main Fuel feed from filter _______l
The connector in the centre of the metering unit goes to the Warm up regulator (Right) connector.
Side view of metering unit-
CLICKY
[Edited on 7/11/08 by Mr G]
Namyllegin
| posted on 8/11/08 at 12:55 PM |
Mr G,
Many thanks for the pickies and scans. Should be allowed to play again tomorrow afternoon so hopefully will get the bloody thing started.
Nige
