| posted on 17/2/06 at 11:38 AM |
Rover inlet on Zetec ?
Anybody using a Rover inlet manifold on a Zetec via an adaptor plate ?
I discovered it dosen't have to be off a Turbo manifold --- the standard T16 manifold has the same part numbers right down the the injectors
although the fuel pressure reguator is different for obvious reasons.
[Edited on 17/2/06 by britishtrident]
| posted on 17/2/06 at 02:22 PM |
Looks like a no then --
here is a couple of related urls
http://zetecescorts.bravehost.com/injection.html
http://ferriday.co.uk/cnc/production.html
bob
| posted on 17/2/06 at 04:24 PM |
Its a good find BT
When i looked at the 2 litre zetec the biggest problem was the size of the inlet/plenum chamber unit, the 1600/1800 is smaller and people have used
this with the 2 litre TB on.
The Rover unit looks far more compact and i'm sure the adapter plate is achievable by the most engineers here.
I see a fair few Rover T's in the scrappy.
stevebubs
| posted on 17/2/06 at 06:20 PM |
Seen it done around and about, but no...
If I ever get round to forced induction, then I'll probably take a look....
romer
| posted on 21/2/06 at 12:20 PM |
'scuse my ignorance, but what's a T series rover?
Or is it just a turbo'd K Series?
Could look interesting that's all as a possibility.
Romer
stevebubs
| posted on 21/2/06 at 03:57 PM |
As fitted to the 220 Turbo coupe...very different to the "K" ... much heavier for a start....
[Edited on 21/2/06 by stevebubs]
| posted on 22/2/06 at 12:49 PM |
Yep ---- goes back to dear old MGB engine but with a 16 valve head --- come along way from the 1200cc engine that first appeared in the the Austin
A40 in 1948.
Seriously good engine, smooth and powerful but too heavy for a locost.
Even the normally aspirated version pokes out 140bhp, turbo version exists in various outputs up to 190 ps stock.
