blockhead_rich
| posted on 19/4/06 at 08:05 PM |
Omex wiring question
Urgent question seeing as Omex themselves are not available in the evening.
I've now got hold of a second hand Omex 500 ECU and I just need a quick pointer as to the wiring of the injectors. From the manual I either a
white or brown wire goes to each injector but where does the second wire emminate from? Would this simply be an earth?
Also, seeing as I bought my ECU second hand, I can firmly recommend OMEX, their customer service has been truly excellent!
Rich
BKLOCO
| posted on 19/4/06 at 08:17 PM |
Hi Rich having fun then
I'm not sure about Omex but generally it's a live and the ECU grounds the ingector.
Regarding your other post don't worry if you f**k up your coil pack plug I've got a couple of spares so you can destroy one finding out
how you should take it apart
blockhead_rich
| posted on 19/4/06 at 09:09 PM |
OK then Brian, I'll get my hammer out unless anyone comes up with a better idea before then!
Thanks for the tip re injector wiring. I guess I'm getting there but very very slowly!
Rich
Dusty
| posted on 19/4/06 at 11:10 PM |
I have an omex ECU and it is switched ignition live to each injector and the brown to 1/4 and white (yellow in my loom) to 2/3.
