Markp
posted on 5/5/06 at 04:55 PM |
Emerald fault
Or so I think,
After driving 200 hundred miles to Stoneleigh I park the car which drove without a glitch, and left it for a few days, It's been nice so I
thought I would take it for a spin today.
The engine turns over but that's it The fuel pump used to charge when the ignition was on but now it doesn't, the fuel pump runs if you
bye pass the relay
I'm at a complete loss, And the car is really Pi**ing me off, One problem after the other!!
Any suggestions (apart from scrap the thing) greatly recieved.
Mark
rayward
| posted on 5/5/06 at 05:11 PM |
has it got an intertia fuel cutoff switch hidden somewhere?.
have you tried bypassing the fuel pump relay, then trying to start it??.
Ray
Markp
| posted on 5/5/06 at 05:13 PM |
I have tried turning it over with the fuel pump bye passed, the pump runs but the engine doesn't start. I can't even see a spark, so I
replaced the coil pack.
Mark
MkIndy7
| posted on 5/5/06 at 05:57 PM |
Check the Crank position sencor if it has one, It will need that to tell it when to spark.
Syd Bridge
| posted on 5/5/06 at 06:20 PM |
Check the timing transducer. If it is not functioning, or its wiring is faulty, the ecu won't get pulses and therefore will not turn on the fuel
pump or sparks as the engine is turned over on the starter.
Syd.
Markp
| posted on 5/5/06 at 06:42 PM |
Ok all sorted,
Thanks for the replys
it was all my fault
Some how a wire had come away behind the dash
Thanks again, sorry be a pain in the ass
Mark
ps - this was no fault of Emerald!
[Edited on 5/5/06 by Markp]
Dusty
| posted on 5/5/06 at 06:45 PM |
If the pump does not do its initial charge on switching on then either its not getting its lectric or its not being sent. Sounds like the ECU is
sulking. Has it blown its supply fuse? If you connect up your laptop does it see it and are the settings and maps OK?
zetec
| posted on 5/5/06 at 07:49 PM |
Easy check with the Emerald is to see if the LED on the case goes green when cranking, if not it is not seeing the flywheel trigger source...
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
lsdweb
| posted on 5/5/06 at 08:36 PM |
Emerald doesn't need a cranking signal to 'prime' the fuel pump - it will always power the pump for a few seconds when switched
on.
Regards
Wyn
stevebubs
| posted on 7/5/06 at 02:07 PM |
quote: Originally posted by Markp
Ok all sorted,
it was all my fault
Mark
I had exactly the same thing last year - engine just stopped running for no reason. Turned out the Emerald earth wire had gone walkies from the
loom...
Feltabout this big
jono_misfit
| posted on 11/5/06 at 07:38 PM |
The most un-reliable things in electrical circuits tends to be connectors.
Whenever anything goes wrong with anything electric, first step is to check connections. Crimps dont always make 100%, Wire break with vibrations, and
if its older corosion affects the contacts.
Next least reliable is polyester capacitors.
Generally anything thats printed circuit based is much much less likely to fail unless it been shorted / got wet etc.
