| posted on 5/1/07 at 11:35 AM |
Best ECU - Zetec Running GSXR TB's
Hiya
Any ideas as to which ECU does the best job for a Zetec runnning GSXR TB's.
Off to spend my cash, but would like some user information...
Ta
Scootz
ned
| posted on 5/1/07 at 11:39 AM |
I wouldn't presonally say there is a clear winner, many products will do the job perfectly with the right map on them. Some do seem more
popular, namely emerald, omex, dta, mbe (loosely in that order) on't forget megasquirt if want the diy approach.
Depending on the ecu you choose I'm sure either the manufacturer/supplier or someone on here can provide a map to at least get it running or
maybe more if its a standard/common setup on the engine.
Ned.
beware, I've got yellow skin
| posted on 5/1/07 at 11:50 AM |
Thanks Ned.
I just wasn't sure if 'standard' ECU's could interface easily with the bike Throttle Pot.
Dusty
| posted on 5/1/07 at 02:17 PM |
The gxsr throttlepot is 0 - 5v just like most ford ones. I'm using Omex which has, like all the others mentioned probably, software settings to
calibrate sensor ranges. Setup was easy. Just plug the laptop in with a serial cable, read the figures it shows on the screen at closed throttle and
full open, maybe have to loosen and rotate the pot to get them in range, set these in the throttlepot window and its done! Happy to read the Ford
crank sensor and coolant temp sensor but you will need to buy an air temp sensor. Controls idle by spark scatter or the ford air bypass valve. Good
fun playing with the settings.
Emerald is much the same but slightly better specced. I would go with either.
miegru
| posted on 5/1/07 at 04:33 PM |
I have very good experience with the KMS one. DTA was good but service was bad (or at least very expensive but more due to dealer in Netherlands than
to product).
I don't know if its possible for you but I think that if you go next week sunday to the autosport international in Birmingham you can score some
good discount if you buy at the end.
I did that two years ago with things like battery, SPA-dashboard and other stuff. By paying cash and no receipt, HUGE discounts were given on the
stuff on display.
I know that for KMS the guy normally doing the rollingroad sessions for them will be in Birmingham. I suspect that to be the same for the other
suppliers. If you are a first to programming these things seeing if you 'match' with them can help you speed up quite fast!
One tip: even though it might cost a bit more: go for a system with a wideband lambda management as standard including a self-learning tool. This is
really great!
For me the tinkling with the ECU is a lot of fun and its great to notice improvements; both in performance and economy...:-)
theconrodkid
| posted on 5/1/07 at 05:28 PM |
try megasquirt
who cares who wins
pass the pork pies
stevebubs
| posted on 5/1/07 at 05:49 PM |
Yep - All std ECUs should i/f directly with the Gixxer TPS.
Wiring diagram in my Archive...
Stephen
(Using Emerald and Gixxer 750 bodies on Blacktop 2.0 zetec)
