Author: Subject: Running on EDIS alone - a slight problem (no longer!)
posted on 5/1/07 at 02:25 PM Reply With Quote
I'm well into the installation of my Megajolt, and have just completed the VR sensor - EDIS - coil bits (the original scrap Ford parts).
I thought I'd try to run the engine before connecting the MJ unit, using the EDIS 'limp-home' mode - all I got a bit of a cough, then a backfire through the carb at the next attempt. It's good news that at least it was trying to fire, but obviously I've got something wrong somewhere. So, can I clarify a few points before I try again?
1.First of all, should I be able to run on EDIS alone? I was expecting to get the 10 degrees BTDC limp-home fixed setting.
2. I connected the plug leads according to the markings on the coil - do I have to change anything due to the crossflow's odd firing order (1-2-4-3)? I don't think I do, but I have to ask.
3. When you look straight at the front of the engine, the timing mark on the block is at roughly 1 o'clock. If I set the crank to TDC so the pulley mark is against the zero timing mark, the gap in my toothed wheel is at roughly 10 o'clock. Have I got this right?
It's not running for long enough to put a timing light on it.
All help appreciated!
[Edited on 5/1/07 by David Jenkins]
scottc
posted on 5/1/07 at 02:44 PM Reply With Quote
I thought the missing tooth was supposed to be 90 degrees before TDC ??
I'll try to find something to either prove myself wrong or confirm.
scottc
posted on 5/1/07 at 02:48 PM Reply With Quote
ahh but of course it depends where your sensor is....
http://www.locostbuilders.co.uk/viewthread.php?tid=55806
posted on 5/1/07 at 02:52 PM Reply With Quote
I'll go back and re-read that thread - I think I'm covering old territory!
But any comments would still be appreciated.
posted on 5/1/07 at 03:07 PM Reply With Quote
I think you will have a problem starting it on the EDIS -10 deg as the engine will be cold and not getting enough fuel to warm up.
Danozeman
posted on 5/1/07 at 03:18 PM Reply With Quote
My zetec runs with just the edis so theres no reason why yours wont run with it.
Paulf's your man for this..
Dan
posted on 5/1/07 at 03:19 PM Reply With Quote
Scottc - you're a hero!
Went back and re-read that thread, and realised that I'd counted 9 teeth in the wrong direction - I think I was trying to start with about 100 degrees advance!
It now runs very nicely, and the timing is near-enough exactly 10 degrees BTDC. I'll set it spot-on later.
I can now move forward to the MJ installation and wire-up knowing that the second-hand bits work OK.
Thanks to all,
