chriscook
| posted on 26/4/07 at 07:08 PM |
VE & AFR Tables
I'm starting to get my MS running well under no load before going off for a drive to tune it. Before I do that it'd be good to see what
AFR and VE tables people have so I can space my rpm and map bins and set my AFR targets sensibly too.
Info on engine type, power etc would be useful for comparison.
If anyone has the above for an XE engine on ITBs then It'd be very interesting.
Thanks.
Chris
TangoMan
| posted on 26/4/07 at 07:38 PM |
Chris, Let me have an email address and I will send you a copy of my map.
Although the engine will have different requirements, using the same TB's and injectors should mean that once you have the base settings the
range may give you an indication.
To be honest, I found it very easy just to give the WB a great deal of control during the early stages to be safe and then use the datalog to close in
on the required values.
Using the above method and gradually reducing the WB control, I found it very easy (but safe) to get a good map.
Summer's here!!!!
