theconrodkid
| posted on 6/6/07 at 04:46 PM |
squirty smeg
ok clever people,ive got just 1 problem with my ms unit now.
the output that fires the pump relay is only showing 5 volts,its not enough to fire the 12v relay,any ideas?
who cares who wins
pass the pork pies
sebastiaan
| posted on 6/6/07 at 05:35 PM |
The fuel pump output is a pull-down output, so it grounds one side of the fuelpump relays coil. The other side needs to be connected to a (switched!)
12V
ChrisW
| posted on 6/6/07 at 05:37 PM |
Maybe the fuel pump transistor is knackered then, Conrod?
Asked on the MS forum for you - there's no setting in software for the inverting the fuel pump, so it *must* be something up with the unit
itself.
Chris
TangoMan
| posted on 6/6/07 at 05:38 PM |
IIRC the output is to earth the switching side of the relay which should be live fed from the main ignition relay. The switched side is then fed from
the battery through a fused connection and this is permanently wired to earth.
I will send you my wiring diagram if you let me have an email address.
Regards,
Summer's here!!!!
theconrodkid
| posted on 6/6/07 at 05:41 PM |
SEBASTIAN SAID....The fuel pump output is a pull-down output, so it grounds one side of the fuelpump relays coil. The other side needs to be connected
to a (switched!) 12V
unfortunately on mine it supplies a + 5 volt for some reason.,tranny WAS replaced Chris,,any ides if i can get a 5 volt relay to fire the pump
relay?
who cares who wins
pass the pork pies
theconrodkid
| posted on 6/6/07 at 05:43 PM |
Tango,ive got a diagram thanks,i didnt build this unit so dont know is something has been done wrong
who cares who wins
pass the pork pies
TangoMan
| posted on 6/6/07 at 06:19 PM |
I suspect it may just be something else backfeeding down your earth, as the same has been found lots of times with the injector switching wires.
Folk often think this is a problem when it is how they are.
Hopefully you don't have a problem.
Summer's here!!!!
theconrodkid
| posted on 6/6/07 at 07:27 PM |
hm,backfeed could be a possibility,but its timing (2 secs or so) is correct.
ill have a play and rewire the relay morra
who cares who wins
pass the pork pies
ChrisW
| posted on 6/6/07 at 10:56 PM |
I'll pop over one night and take a look if you like Johnski? Everything looked ok when I had it apart here at the weekend.
Chris
theconrodkid
| posted on 7/6/07 at 05:40 AM |
cheers christof
who cares who wins
pass the pork pies
| posted on 7/6/07 at 08:44 AM |
relay?
Is it a V3 or a V2.2? If the V3, the fuel pump relay driver has current limiting built in, if it's not pulling all the way down to ground then
it's possible the wrong current sense resistor has been fitted. R40 should be a 1/2watt 1 Ohm part (first three bands will probably be Brown
Black Gold).
Does it pull to ground with no relay connected ?
bob
| posted on 7/6/07 at 10:43 AM |
I have a feeling its V2.2 but i'm sure john will clarify later
theconrodkid
| posted on 7/6/07 at 03:51 PM |
yup,it says V2.2 on the pcb,just tried the back feed theory and its a no go.
still getting + 5v at that terminal for the pump prime period and when the engine in running
who cares who wins
pass the pork pies
martyn_16v
| posted on 7/6/07 at 07:45 PM |
What does it do when it's not at 5v (i.e. after the prime period, but before you start cranking)?
matt_claydon
| posted on 7/6/07 at 09:17 PM |
You need to check D7 is a) the correct component (1N4001 diode) and b) the right way round.
To verify, check the voltage at each end of the diode, you should get 12v at both ends. If you get 12v one side and 5v the other then this is your
problem.
One end of the diode is connected directly to 12 volts and the other goes through a transistor and then to the relay. When the transistor receives a
signal from the processor it closes the circuit and you should get 12v at the output.
I think D7 is a zener diode which means it clamps any voltage going through it the 'wrong' way to a specific voltage (in your case 5 ish).
If the diode is wrong then you will only see the 5 v at the other side instead of the full 12.
[Edited on 7/6/07 by matt_claydon]
| posted on 8/6/07 at 11:15 AM |
The 1N4001 is just a simple rectifer, not a zener, so if it were fitted backwards the relay output would have ~12v continuously, and transistor Q3
would be dead a couple of milliseconds after switching on. It's quite possible a zener has been fitted accidently of course, but that should be
easy to identify as 1N4001's have the code marked quite clearly on the body.
One thought: the Base-Emitter junction of an NPN transistor like Q3 acts like a ~5v zener if reversed biased, so make absolutely sure the transistor
has been fitted to the PCB correctly.
theconrodkid
| posted on 8/6/07 at 05:01 PM |
cheers for your replies peeps,looks like a job for superchris
who cares who wins
pass the pork pies
theconrodkid
| posted on 9/6/07 at 02:51 PM |
d7 and q3 are both the right way round.
voltages are 11.5 and 10.7 on d7,but with wire to pump relay disconnected the voltage at d7 drops to 00.2
ohms are 1.68m and 3.o4m ohms depending on what way round the leads are....any help?
who cares who wins
pass the pork pies
paulf
| posted on 9/6/07 at 07:05 PM |
Are you sure that the output transistor has not been damaged ? it could have been connected directly to 12v or fuel pump with no relay? if so it may
be supply ing a 5v output when measured with a meter but at probably very low current due to leakage, instead of conducting the supllied 12v to
earth.
Paul.
theconrodkid
| posted on 9/6/07 at 07:39 PM |
output tranny was replaced just in case,its always had a relay in the circuit.oh well
who cares who wins
pass the pork pies
matt_claydon
| posted on 10/6/07 at 08:42 AM |
Sorry John, am at a loss as to what the problem could be if you've replaced the components and it's still not working. Top right diagram
of Page 3 of this PDF shows the circuit and where is should connect: http://www.bgsoflex.com/v22/megasquirt_ShemV2.2.pdf all I can suggest is that
you check all the components are connected externally and to each other correctly. Otherwise I think you need someone good with electronics to look at
it in the flesh!
Good luck
| posted on 10/6/07 at 10:13 AM |
One thing I forgot to mention, some automotive relays have a built in diode to suppress the back EMF when the relay is opened. If such a relay is
connected backwards, it will appear as a virtual short circuit to the relay driver transistor.
If your relay is of this type, the Megasquirt output MUST be connected to the correct side of the relay coil. From a relay I have to hand this would
be pin 86 of the relay, and pin 85 should go to your switched ignition supply. However, I think this can vary so check polarity on yours, switched
ignition supply must go to 'bar' side of diode.
Apart from that I'm running out of ideas. Does the relay operate if you ground the fuel pump relay output pin of the Megasquirt? (this will not
damage the MS if it has been built properly since it's an open collector output).
[Edited on 12/6/07 by MikeRJ]
theconrodkid
| posted on 10/6/07 at 12:45 PM |
its only a cheapie relay Mike,its only putting out 5 volts so wont fire the relay,thats the main prob,ive mailed my tame electronics guru and am
waiting for a reply,ill let you know if we find anything.cheers John.
who cares who wins
pass the pork pies
paulf
| posted on 10/6/07 at 08:24 PM |
The megasquirt doesnt put out any voltage it just connects the relay coil to ground.The other end of the relay should be connected to +12v and if you
connect a wire from the pump output pin on the relay to the chassis it should pull in the relay.you may be following a false lead by thinking the
output should be 12v as it should not read anything when energised and may show a voltage on a volt meter when not energised .It should show 12v when
the relay is connected and ready to operate though , if it is all connected and still only showing 5v then it looks as if the relay or its connection
to 12v is faulty.
Paul.
